How to auto power on device while DC charger is plugged in
    Hi
    I have a question, is it possible to setup device somehow to auto power on when device power plug is connected ?.
    Currently when I connect device plug to 220AC it goes in suspend state and I need to turn it on using IR remote or by button on the device itself.
    I want to use box with mice and hide it somewhere so no IR remote will be used, and I want to turn it on using relays in wall plug.
    So is there any way to setup system so it boot while power DC charger is powered from wall plug ?
    Cheers
    You need a new bootloader for that.
    Maybe there's another solution but I'm not aware of it.
    if [ $up.post.type = $type.two.lazy.to_use_google ] || [ $up.post.type = $type.silly_question ];
    then mv $user.contact.up.post /.trash; set response($response.type = ignore);
    $user.up.post.ignore_in_future = true; fi;
