I guess what I am looking for specifically is just to get Google Play (or Android Market) on the tablet. I did what I saw on other sites, and while it "seems" to be loaded, every time that you go to open the market, it states the application has stopped working. Seem to be so close, yet so far away.
Is there Rom/Root for Polaroid S7?
Thanks for your help. Didn't mean to come across as rude.
Re: Is there Rom/Root for Polaroid S7?
Originally posted by balrogbob View PostWe have a RK3066 based tablet. :P just found out. Thought you ought to know...
Sent from my HUAWEI-M931 using Tapatalk 2
Originally posted by jtintle View PostIf it is a RK3066 Finless should be able to help you out with this tab. Maybe get CWM on it for easier flashing. Drop him a message and see if he can help or point you to someone who can
Problems with Google Play stopping unexpectedly
Originally posted by jfnz24 View PostThanks for your help. Didn't mean to come across as rude.
And I would also like to give a big thanks to balrogbob for the instructions on rooting this device. You are awesome with out your guide I never would have been able to get this accomplished.
Originally posted by balrogbob View PostAlrighty. First, What you need:
A crappy app, called Moborobo. It does some wicked magic to make adb work with this tab without drivers, tho. Download from their website: www.moborobo.com/ EDIT: moroboro installs 2 apps on your tablet, just remove them when done.
This zip file: https://dl.dropboxusercontent.com/u/...Bin4ry_v30.zip
or, the one with gapps: https://dl.dropboxusercontent.com/u/...plus_gapps.zip (give it a couple hours from the post time to finish uploading.)
Step by step without Gapps:
1. Install Moroboro.
2. Start up Moroboro.
3. Enable USB debugging under Developer options in the system menu.
4. Plug in the tablet.
5. Wait for Moroboro to display info about the tablet. It should show free space on your tablet plus its correct name.
6. Shut down Moroboro.
7. Extract the zip file (either one for this step, but use gapps one if you plan to install them.)
8. Double Click RunMe.Bat
9. Select the first option, say yes to any prompts.
10. Wait. the tablet will reboot a few times, don't unplug it. DON'T UNPLUG IT.
11. After final Reboot you have root!
12. ???
13. PROFIT!
The Gapps step is DANGEROUS! But only if you don't follow my directions EXACTLY. Copy and past any commands. Don't type them, just to be absolutely safe. I take no responsibility if you brick your device. You can most likely install the standard set of apks as a user, but this method gets almost everything in market showing up, no restarts, no errors, no crashes. All sync working, and paid apps.
1. Open a command window and navigate to the extracted contents of the root zip. DON'T extract the gapps zip. leave it alone.
2. Paste this command into the command window and press enter: adb push gapps-jb-20121011-signed.zip /sdcard/
3. Do the same for these commands:
adb shell
su
mount -o remount,rw /system
busybox unzip /sdcard/gapps-jb-20121011-signed.zip /system
4. When it asks to overwite a file, type a, it may need to be small or caps depending on the prompt.
5. Cross fingers and pray.
6. Paste these commands:
mount -o remount,ro /system
reboot
7. Once the tablet reboots, launch play store, enter credentials, and download any gapps that need updating or didn't install. The gapps package I use has some of the memory hogs removed, they can be installed through market.
8. ???
9. MORE PROFIT!
EDIT: you may also be able to do this same thing with root explorer or es file explorer in root mode. I dont want to re-risk my tab to test that tho. I've done the adb method twice now without problems.
BalrogBob, once king of the PLANET(Pandigital), now king of the Ess of Sevens!
Originally posted by elektrik View Post*raises hand*. I would be the .bat making fool, except I have zero time as it is right now :-/
P.S. Sending love to Balrogbob ha ha.
Sent with Carbon Strength using Tapatalk 2
Not a rebadged PMID720
Just wanted to toss in that this can't just be a "rebadged" PMID720 - as the 720 has a screen resolution of 800x480
Which is too bad, because I could really use anything relevant to the PMID720... though I am interested in looking at moborobo and trying the busybox-based version of putting gapps in place off the zip!
Anyway, I'll continue to follow the thread. Thanks all
Moborobo
Originally posted by Briteyez83 View PostJust recived one of these babies and I cant seem to get the app off www.moborobo.com to install. It downloads just fine but when i used es file explorer to open and install i get a pop up that says "can not open file" I even deleted the download and redid it but still no install. If i tap on the download in es file explorer my only option is to open as either text, audio, video or an image. Any idea what might be wrong?
Originally posted by HawkICompuFix View PostBriteyez83: not sure if this is still needed, but I noticed you stated you are trying to install the app on the tablet. It should be downloaded and installed on your PC not the tablet.
Originally posted by Briteyez83 View PostSo I did everything that you listed and was able to get a google play apk on my tab but every time i go to open it the dang thing fc on me. Is there something im not doing right? The apk is a converted torrent btw. Thanks
*Originally Posted by*jfnz24*Thanks for your help. Didn't mean to come across as rude.I guess what I am looking for specifically is just to get Google Play (or Android Market) on the tablet. I did what I saw on other sites, and while it "seems" to be loaded, every time that you go to open the market, it states the application has stopped working. Seem to be so close, yet so far away.jfnz24 I was fighting the same problem as you for nearly 2 weeks. until I stumbled upon a suggestion for another tablet that stated to make sure the Google Play store is installed in the system/app folder instead of the data/app folder. I was able to move the file (com.android.vending apk) with Root Explorer and it has been working fine for 2 days now. I have been able to install, uninstall, reinstall, and update apps with out any issues since making this change. I also ensured that I have google play services and google services framework installed as well. Although I did this prior to finding the suggestion of system/app so not 100% sure that you need to install both or if they may already be there.
Originally posted by HawkICompuFix View PostBriteyez83 did you verify the location thst the google play apk was installed to? See below for I nstructions. Also the apk you have may be corrupt. Try this apk: https://dl-web.dropbox.com/get/com.a...cL0Q2Sbur9Bz3g
Sent with Liquid Smoothness from my Maserati using Tapatalk2
So I was able to get play store on my tab, even have su asking for permissions so I'm obviously rooted. My question......are there any roms available or has any even been developed for the S7?
Root & Google Play
Big thank you to balrogbob for helping get root! The deal with that crappy software was actually a HUGE help with getting ADB to work.
I had a little difficulty getting and keeping root though, so I used this http://forum.xda-developers.com/show....php?t=1886460. It actually allowed me to keep root...I don't know why, but I was only getting temp root for some reason? But the updated code from Bin4ry made it stick.
The gapps thing doesn't work for whatever reason, but I found something else that does. Again from XDA, I found that the process for getting the Play store to work on a Kindle Fire HD was the same for any rooted device. It's a fairly easy process and all the instructions and files can be found here:
http://forum.xda-developers.com/show....php?t=2365224.
I'm working on getting TWRP or Clockworkmod recovery binaries to work with this tablet so that maybe I can get Cyanogenmod to work on this tablet. I got it for 50 bucks at Kohl's so I'm going to see what this thing can do. I got to say that out of the box, the battery really sucks and with Apex launcher, the touch screen is really buggy. But, all in all, it's a great 50 dollar tablet for my four year old daughter to play her favorite apps.
Thanks to all of those who did the development for root and such. I wanted to contribute what worked for me and what didn't. Of course, your mileage may vary.
Hope this helps someone!
How do you like this tablet? The S8 is on super double secret sale at Kohls ($40 rebate)...Polaroid S8
Blackberry Torch
Kindle Fire HD Gen 2 - Wifes
Nokia 520 Windows 8 - Wifes
(3) Nextbook 7s - Slooooooow - (Finless Bob ROM) - used for kids e-readers
(2) Samsung Exhibits - kids
Samsung Blaze, Kindle Fire, (2) PMID701c (Elektrik ROM) - all RIP
...some laptops, some PC's and some routers / switches
There are currently 2829 users online. 1 members and 2828 guests.
