Remix OS back to normal Android by SD?
Can anyone help with this? My computer won't recognize the S95 Telos so I'm stuck on the Finless Remix OS AND can't revert back to stock or any other rom. I want to get out of the Remix OS because the youtube app only shows 720p as the highest resolution. Ive tried changing the build prop but it didnt help. I can get into recovery on the Remix OS but can't flash anything I've put in a sd card like Finless or the latest update from Tronsmart. It starts to install the zip but fails due to some kinda of signature fail. Can anyone help???Tags: None
Originally posted by Berial3XDid you also try using OGYoutube? Too bad this box doesn't have recovery or xposed. At least I didn't try any xposed framework, afraid not to brick it heh.
Originally posted by Berial3X View PostYou also need to install 3 other apk from ogyoutube page to be able to log in, check it carefully. 60 fps should work, I also have ogyoutube on my phone and I think I watched some 60 fps clips.
Ok got it thanks! Any idea why no 60fps option? Also any way to flash stock firmware or even the update and backup apk to the Remix OS?
To go back to Android OS you have to use the USB Burning Tool on your PC and use a Male to Male connector usb cable and flash back a stock ROM from Tronsmart website.
Firmware.
http://forum.tronsmart.com/forum/veg...eased-20160413
USB Burning Tool - google it the latest version i see so far is 2.0.7
USB male to male cable - buy one if you do not have one
During flashing your box will be wiped/formatted and reset you will lose all your settings/files/software - from here you will start again.
Instructions for flashing
Good luck
Firmware.
Good luck
I have tried my self the way you are suggesting and no it does not work the only way is use the USB Burning Tool.
I also have a G-Box Q the way you are suggesting does work but not with the Telos I did initially install Remix then got stuck as no way to go back so re-flash and start again.
I have not bothered with Remix since, I do not like that they provide a way to install but not roll back.
Originally posted by RISCy DudeTry the method here. Also you may want to try manually installing the WorldCup USB driver.
It is important to push the USB Burning Tool's start button before connecting the S95 to the PC.
Good luck.
Have you tried the latest version of Kodi Youtube and Telos firmware h**p://forum.tronsmart.com/forum/vega-s95-official-firmware-releases/2201-new-firmware-for-vega-s95-released-20160413
If you like if you list the exact instructions you are doing I can try this out on my Telos to see what I get ?
There are currently 2516 users online. 2 members and 2514 guests.
