MK808B Pro Flash Firmware failure
    Never ran into this before. MAC Key failure. Know how to get around it?
    I don't own this device.
    This has been seen on other S905(Vega S95). The following is for the S95, but a similar solution might be found for the stick. You may find a License.zip file in the update package.
    The solution in that case(excerpt from here), "In the above photo, the part 1 is showing the firmware you just loaded, and please note, if you see the part 2 error (mac 0), Please follow the step 4, if NOT, just ignore and see the step 5.
    4) Download this file to your computer, unzip it, and copy the whole folder which is called" License" and then go to your "USB Burning tool" Installation directory, For example, if you put the USB burning tool in C:/ Program Files(X86)/Amlogic/USB_Burning_Tool/, paste the "license" folder you just download, and replace the existing one, and then repeat the step 3.
      Appears to be working. Flashing now thank you.
