DeePoon V3 Mobile VR Headsets from LightintheBox
    DeePoon V3 Mobile VR Headsets from LightintheBox.com
    Virtual Reality is the Buzz Word of the Day. Everybody want to try it out.
    But mostly a good VR Device cost a Lot. Here comes the DeePoon V3 Mobile VR Headset.
    It has a really good Build Quality and is Ideal for 5" to 6" Phones.
    Seems there is nothing stopping theDeepoon series of headsets. They always fall into the mid-range price category
    and always seems to be high quality. So is this new one any good? Well, it sure looks different to the others in the same range.
    With its bar on the front rather than an enclosed case, and it’s comfortable and breathable magic-hair-flow face padding.
    While it might look a little prickly it isn’t and is designed to enable the skin to breathe also making the lenses less foggy.
    The design of the headset has also had a little makeover. Its special shape is designed to eliminate the pressure of
    weight at the brow ridge and the nose. It is also lighter in weight but yet still packs all the features previous models have had.
    The whole H
    eadsets just feels lighter and much better made than any previous model.
    The gripper in the front seems to hold the phones in security and it does feel quite immersive.
    This headset might be on the small side, but it packs a punch when it comes to everything else.
Name:	DeePoon-V3-3D-Virtual-Reality-Glasses-Headset-Head-Mounted-3D-VR-Movie-Game-Adjustable-Splint-headband.jpg
    As you can see for the Price of 49,99 $ you get an Amazing Build Quality.
    I Test it with Various VR Apps on my Phone and I must say I were saying just WoW.
    Deepoon V3 Top Points:
    1. Suitable For Smartphones 3.5″ ~ 6.0″ Screen Size
    2. Convenient And Comfortable To Use
    3. High-Quality Spherical Resin Lens
    4. Runs All Google Cardboard Apps
    5. Adjustable Head Girth Strap
    6. Adjustable Pupil Distance
    7. Adjustable Sight Distance
    8. Strong Front Locking Bar
    9. Made From ABS Plastic
    10. TPU hollow design
    Here we have a Unboxing Video for you from our Partner Site in the UK:
Name:	Deepoon-V3-Immersive-3D-VR-Virtual-Reality-Glasses-VR-Goggles-FOV96-Video-Game-VR-Headset-.jpg
    You can Buy this Amazing Product here:
    http://www.lightinthebox.com/deepoon...forum_freaktab
    Neomode
    hello Dear, i found the cost is down, $29.99 now!
      Great Deal!
      Will correct the Price 😃
