Custom ROM for MXQ 4K
Originally posted by 251643711 View PostI am the only problem to complete the x1II. zidoo transplant is illegal equipment tips
ifconfig eth0 down 192.168.1.22
iptables -A INPUT -d 203.90.239.13 -j DROP
iptables -A INPUT -s 203.90.239.13 -j DROP
iptables -A INPUT -d 106.75.199.228 -j DROP
iptables -A INPUT -s 106.75.199.228 -j DROP
ifconfig eth0 up 192.168.1.22
I did a crutch. In the very firmware to the beginning of the script /sytem/bin/zidoopreinstall.sh put these rules to iptables. The first boot is proceeding normally. Also, I added in the firmware support the init.d, but the scripts are in the folder for some reason do not start (Permission denied). The idea, then it would be possible to establish from zidoopreinstall.sh /etc/init.d/01_zidooauth.sh:
But in fact, the option to ifconfig, I have not tried yet. So just deleted /data/system.notfirstrun, original zidoopreinstall replaced the one in which there are rules when you turn off the set-top box to chop off ethernet. Need help with init.d
Lonix transplanted X6 firmware perfect solution to the problem of activation, there is a patch preinstall.sh activation, but 3229 on the useless
script:
#!/system/bin/sh
echo "do preinstall job" >> /data/log.txt
touch="/system/bin/touch"
PM="/system/bin/pm"
if [ ! -e /data/system.notfirstrun ]; then
APKLIST=`ls /system/preinstall/*.apk`
rm -r /data/dec_out.h264
rm -r /mnt/sdcard/contorl
for INFILES in $APKLIST
do
echo setup package:$INFILES >> /data/log.txt
$PM install -r $INFILES
done
touch /data/system.notfirstrun
fi
if [ ! -e /data/kodi.installed ]; then
/system/bin/pm uninstall org.xbmc.kodi
/system/bin/pm install /system/kodi/kodi.apk
touch /data/kodi.installed
fi
echo "preinstall ok" >> /data/log.txt
Originally posted by buba5473 View Post
The solution is to drop from packets authorization servers zidoo. But there is a problem: power on the box should be disabled with ethernet. Perhaps the solution would look like this:
Asked him to help do not answer me, do not know how to solve
Is it possible to make auto pppoe connection work? because when i set up pppoe after pover on/off device need again to manualy check up again
and other issue is when make connectio box with tv via AV port on older TV only black/white screen, this is fixed only if in tv mod option i set from PAL to NTSC but after power on/off device there is no picture at all, only on HDMI but via AV there n picture, any solution for this
There are currently 2132 users online. 0 members and 2132 guests.
