Beelink MiniMX 1GB/8GB + 2GB/16GB - Firmware version: 107L1 - April 20, 2016
    Here is the Beelink MiniMX 5.1.1 for BOTH the 1GB/8GB and 2GB/16GB Android 5.1.1 Firmware - 107L1
    FOR 106L1 FIRMWARE SEE THIS THREAD
    Works on aliexpress & gearbest models. I DO NOT know if it works on the Beelink MiniMXIII
    107L1 (20160420) Changelog :
    1. Optimization system
    2. Minor bug fixes
    MiniMX 1GB/8GB - s905_107L1 (April 20, 2016)
    MINI MX-1+8(107L)
    OTG: https://mega.nz/#!ylkhDAqb!m-chlqL1s...RWxyqD5IqT2hSQ
    SD: https://mega.nz/#!Xk82nTxK!JS31rZtZJ...t5yiO2-lEh7ph0
    Source:
    MINI MX-1+8(107L)
    OTG: http://pan.baidu.com/s/1qXPqK9m password:1cqc
    SD: http://pan.baidu.com/s/1bp7G9OV password:8tm6
    MiniMX 2GB/16GB - MiniMX-G-107L1 (April 20, 2016)
    MINI MX -2+16 (107L):
    OTG: https://mega.nz/#!agdVkC7S!LB5G8mpT8...9bBHQabncwXuAM
    SD: https://mega.nz/#!ixMyzaxR!TzvmbvtFc...jcnw378UAxg-HA
    Source:
    OTG : http://pan.baidu.com/s/1qY8BZdE password:3uwk
    SD : http://pan.baidu.com/s/1eRZK6sy password:dpbk
    To use Baidu links a Baidu Account is required, use Google Chrome as translater and signup for account.
    The link doesn't seem to be working for me...
    Also, will this firmware work on the Beelink MiniMXIII (2gb/16gb) ? Or are you referring to another Beelink product?
    Thanks!!!
      Links updated, there is both Beelink MiniMX 1GB/8GB & 2GB/16GB models.
      I will updated op with mega mirrors when I have time.
        The links below are copy and pasted directly from Beelink factory email message.
        MINI MX-1+8(107L)
        PC upgrade: http://pan.baidu.com/s/1qY8BZdE password:3uwk
        SD upgrade: http://pan.baidu.com/s/1eRZK6sy password:dpbk
        what is md5sum of 2GB/16GB SD upgrade? I have
        30243728ce07961baae38941111522cb【批量下载】recovery等.zi p
        but I cannot unzip the file
          Mirror
          MINI MX-1+8(107L) OTG
          Diese Website steht zum Verkauf! share-online.biz ist die beste Quelle für alle Informationen die Sie suchen. Von allgemeinen Themen bis hin zu speziellen Sachverhalten, finden Sie auf share-online.biz alles. Wir hoffen, dass Sie hier das Gesuchte finden!
          MINI MX-1+8(107L) SD
            thanks closy for mirror
              I just noticed that you specifically said that you DO NOT know if it works on the Beelink MiniMXIII.
              Sorry about that, and thank you!
                Originally posted by closy View Post
                Mirror
                I see now it is the 1+8 ... do you have the 2+16 mirrored as well?
                  Mega links added for both 1G & 2G.
                  To download from Baidu use Google Chrome as translater, signup, then download files. They take forever @ 100 kb/s
                    Yes I haven't got my hands on a MiniMXIII yet to test but probably not.
                    I can request MiniMXIII original firmware from factory though.
                      I have one that should be here in the next week or so from gearbest. It should be rooted, which would make things a bit easier.
                      Either way, I was hoping to get a recovery installed while maybe messing with the ROM, but I don't dare without a good procedure and factory ROM at hand.
                      I've been trying to hit beelink's website, which I could about a week ago, but it's not working for me.
                      Sooo... in other words, that would be extremely helpful.
                        I asked factory, just waiting for a response.
                          Thanks for the uploads. my Baidu downloads did stop and gave faulty (presumably inclmplete) files.
                            Ya the Baidu site is a pain in the ass.
                              2. Minor bug fixes
