MK808B Pro network connection is terible any advice?
    Hi all.
    Today i received my order of three MK808B Pro's after being very happy whit the MK808B but the new one is terrible.
    It is a nightmare to install a single app not to mention watching a movie.
    ​Speed-test app doesn't even want to start always shows network problem.
    Can any one give me an advice what to do. Otherwise i will have to return them to the seller.
    Any help is appreciated !!!!
    Not Solved:
    neomode's custom rom did made it work better but wi fi is still a crap. One day works ok on the next it doesn't.
    also i couldn't flash the update before because of USB Burning Tool 2 0 5 giving me error LOW_POWER
    USB Burning Tool 2.0.7.2 did the job
    Many tanks to neomode. I was about to send them back to Geekbuy
    Easy :-)
    I will release a Custom Rom for that Device today.
    This Device needs a Neomode Custom Rom :-)
    Neomode
      I plan to buy one but just wait for someone launch custom ROM to make it better. Device itself is cheap but ROM is never good same like old time MK808. Thanks neomode for making it better. I would like to see if it can be overclocked and attach more heat sink to make it run faster would be nice.
        I would pull the antenna out like a small flag....it helps substantially on other devices.
          It's a beast of a thing
          WIP
            Heat sink wasn't enough for me....I had to add a fan too. I got up to 70+ quickly when i stressed it. My fins weren't as tall so you may have better luck. For the price i am really happy with it. I like modding.
              Looks like an operation took place lol
                Underside also get equally as hot bit of thermal pad and copper plate on a penny will help Click image for larger version
