Teamviewer Remote Control support on Rockchip RK3288
    Hi
    Teamviewer said they can make an add-on for unsupported Android devices but then they need to get enough demand
    for a particular device to do it.
    Teamviewer QS works on RK3288 but the Remote Control screen function on a PC doesn't register any response on Lollipop firmware.
    I tested it on Kitkat firmware and everything worked so it must be something with Lollipop and Teamviewer not getting the correct permissions or requiring a new add-on to work correctly.
    So everyone if you have a Rockchip RK3288 device please complete this form
    Remember to say Rockchip RK3288 and not the manufacturer or seller you bought the device from please
    otherwise it's not going to help.
    and also post in this thread if you have submitted that form so we can see how many people have reported it so far.
    Sent
      Message sent.
      Thanks for the info prahjister. I have no active email app on my phone, explains why I got the error.
        it just fills out an email for you to hit send. Here is the format
        [email protected]
        Subject: Feedback - Remote control Android devices
        My name=First Last
        The company I work for=
        Device manufacturer=Rockchip RK3288
        Number of devices=1
        My message=Unable to remote control
          email sent
            done.
