Anyone try the Sixaxis app yet?
I've tried it.
Originally posted by felixaj View PostI ran the initial test app to make sure it was compatible and it passed, but I do not have a PS3 controller.
Originally posted by Frostbyte View PostIt functions well with finless firmware on it. My only complaint it that it only recognizes 2 touches and a time which kinda ruin the whole fps experience. But other than that it functions great. Tomorrow I was planning on testing the joystick app. I purchased it so tomorrow I can put it to the test. I wanted a list of games that properly run on it so I can go through them setting up the profiles. But to answer your question. Yes it does work of the mk908 and t428.
Originally posted by guilds100 View PostWhat game did you use it with? I tried it with dungeon hunter and sg dead zone and I cant get it to work .
So my list:
Beat Hazard (works)
Quadropus (works)
Inotia 3 and 4 (works)
Grudger (works but no need to set profile)
Rayman Jungle Run (works)
Chaos Rings (works but easier to play with alittle help from a mouse)
Modern Combat 2 (works but strange reticle glitch)
Slingshot Racing (menu issue for mouse but if you set the profile for start menu it works)
I cant list the Kemco games and Handy games because I can remember all the games I have and havent test. I'll check and add more later.
I just purchased a DualShock PS3 controller and paired it with the Sixaxis app from the Play Store. It works very well, much better than I expected. I played Modern Combat 3 for about an hour with no issues. When configuring the touch profiles, you will have to play around with the rotation of the profile. Mine was rotated 90 degrees so just had to make sure I changed the settings in the sixaxis app. Also, make sure you start the game first, then take a screen shot, then go back into the sixaxis app, because you can set that image as a background when you start placing the buttons on the screen. This is awesome!!
Originally posted by felixaj View PostI just purchased a DualShock PS3 controller and paired it with the Sixaxis app from the Play Store. It works very well, much better than I expected. I played Modern Combat 3 for about an hour with no issues. When configuring the touch profiles, you will have to play around with the rotation of the profile. Mine was rotated 90 degrees so just had to make sure I changed the settings in the sixaxis app. Also, make sure you start the game first, then take a screen shot, then go back into the sixaxis app, because you can set that image as a background when you start placing the buttons on the screen. This is awesome!!
Originally posted by Frostbyte View PostHey felix which rom are you using. And is you reticle centered on modern combat? I think I loaded modern combat 2 and it had the reticle issue. I had the controls working on it but that reticle was annoying. Lol
There are currently 3002 users online. 1 members and 3001 guests.
