is most likely if you're using an adapter that gives you male mini hdmi to female hdmi. I used 2 different adapters and flickering with both. I then switched back to the adapter that came with the MK908 and it worked with no flicker at all. Watch a full episode of top chef on xbmc with no problems.
Flickering video
Flickering video
So if anyone is having an issue with flickering video the problem
is most likely if you're using an adapter that gives you male mini hdmi to female hdmi. I used 2 different adapters and flickering with both. I then switched back to the adapter that came with the MK908 and it worked with no flicker at all. Watch a full episode of top chef on xbmc with no problems.Tags: None
Originally posted by demost View PostSo if anyone is having an issue with flickering video the problem
There are currently 1727 users online. 2 members and 1725 guests.
