OTT Mxq pro 4k xbox controller
    Does anyone have a way for the Mxq pro 4k to work with a xbox 360 controller.
    I tried using the normal modules but i think they need to be compiled against a 64 bit os to work ?
    Thank you.
    Thank you user wwewwewwe for uploading the 64 bit modules here (http://freaktab.com/forum/developmen...=1462655980187)
    if you load these with insmod they work on the mxq pro 4k s905.
    (http://freaktab.com/filedata/fetch?id=552781)
      Any information about the logitech F310?
          Hey Bedbug1226 know this is old and I hate to bring it back but I've been trying to get any controllers (xb1, ps3, xbox 360) to work with My mxq s905 6.0 4k box. Could you possibly give me a little bit of guidance to how you got this working. I tried researching insmod but didn't find much pertaining to what I need. I'd really appreciate any type of guidance. Thanks in advance!
