Play Store in the original firmware did not work so I had to flashed it with another ROM.
Now I cannot not get into the Recovery Mode using the tooth-pick method (>30 sec press). It went straight into the Android main menu. It looks like the box lost this function after I managed to flash it with the Geekbuying firmware for this MXQ Pro box. The box seems to be working OK with a few quirks but it lost the ability to get into the Recovery mode.
Is there a way to restore the Recovery mode?
The original ROM: "ro.build.description=p201-userdebug 5.1.1 MXQ-Pro 20160413 test-keys <=== need to download this ROM. Does anyone know where it is?
Board version: MXQ_S905_V2_0_2015112
I have not found an older or newer ROM that worked 100% with it. Does any know where I can get this ROM as it was overwritten?
Thanks.
