Need Current M8 img file for USB tool
    I managed to salvage 4 out of 7 DOA Amlogic M8's using the USB method and an " *.img " file (which uses a different *.img file than the SD card method)!
    Only problem is I cant find a current M8 " *.img " file (about 700+/- mb approx) with Kodi 15.2 and/or up! The M8's open up with a "Google TV" logo and have KODI 14.0!
    Also as it stands the IR remote doesn't work, but a wired remote will!
    Can anyone point me in the right direction for the latest M8 *.img file? thanks.
    I have rescued two M8's and two M8N's!
    thanks pclpatop
    File used: S82_109k4.img 654,420,668 bytes
    Let me ask everyone this . . Can I take a working M8, capture the image and then re-write it to these problem child M8's! If so how? and with what?
      did you ever get the m8 img file
        NO I did not, still have 3 dead M8's! I have since moved on to MXqPRO'S! MUCH quicker!
        I have an image for the MXPRO . . .
