EWEAT R9 RTD 1295-DD 3D media player 2/16GB AC WiFI 10/100/1000 LAn BT4 HDMI In/Out
    Firmware update for the Eweat R9
    1. add the subtitle off option by default
    2. solved the some app can not installed issue
    3. Solved characters are missing on subtitle issue
    4. Ratio on fit by default
    5. Add the tool bar function
    OTA updates enabled
    Improved Record Function
    https://mega.nz/#!4sUBXTZA!RxQc6-wkNuQtTbMQ0kD4Slu50b6y2Usudi9prrwfdX4
    Extract all files to USB Key...and insert
    Hold Reset button 5 or so seconds power on
    Will wipe all data.
ID:	638403Click image for larger version
        Need help in porting the firmware from zidoo x9s.
        The firmware is installed and started, but there is no authorization, writes illegal software.
        I have a full factory image Eweat, and a key file with a mac address. And there is also a utility for flashing this image using a computer.
          Can this firmware flash to beelink SEA I .. cannot wait beelink to solve the box problem.. need to try other option...
          MINIX U1, MINI MXIII, MINI MXIII II, GT1, SEA I
            Do you need to modify the firmware? Indicates that illegal firmware can be shielded
