New Firmware With New Features - OTA Next Week....
I have problem with automatic OTA update. Sytem properly detect new update (3.0.6), but after clicking on Updating, it goes to DownLoading updates,… but no download (0%).
Then try to update OTA with incremental udate.zip file which was manualy downloaded from Ugoos page and copy that file to root dir and then reboot. After reboot I was asking for install the update and system reboot. Then i ended in recovery. After reboot of recovery nothing was updated.
So what is wrong?
Hi H-Tab
i thing OTA only work from 3.0.4,not with older Version and the update.zip must be moved to internal SD,if this dont work try external,otherwise you have to flash the newest Firmware with PC,but dont forget to Backup your Userdata.I always use
TitaniumBackup and copy the Android/data/obb Folder to my SDCard.
What Device do you have???
Hope it helps
gefattern
Originally posted by H-Tab View PostI have problem with automatic OTA update. Sytem properly detect new update (3.0.6), but after clicking on Updating, it goes to DownLoading updates, but no download (0%).
So what is wrong?
Yes, OTA update to 3.0.6 available only from 3.0.4
Hi
Thanks AvA,i hope that this Version is a big step in the right Way & it will solve my Wifi Problems.
AvA what about Xposed Installer,will it work too???
Nice that it is possible to use Icon Mode only!!!! I really like that.
have a nice Day
Hope it helps
gefattern
None of all those options for update work. In recovery, update starts fine, but in the middle of update, it stops - update was not successfull. Currently i'm on 3.0.4. After a ew updates, system wont boot any more - hangs on boot logo forever, so i will loose all of my data now. What a pitty ...
Dear, AVA, please tell me whether the control function is implemented prefix the TV remote control via HDMI cable (CEC-HDMI mode). It's very easy to control and one remote control and TV-top box. If this function is not implemented, then please tell me whether it will be implemented in the future. After all, the good old consoles MXQ and MINIX , this function works brilliantly. Please forgive me for my english
try to boot to Recovery,press Powerbutton and Recovery at same Time leave PB and give Recoverybutton free after a few Seconds and it boots to Recovery,normally,then you can try wipe the cache & try booting again.
Hope it helps
gefattern
Thanks for helping.
Hi H Tab
splitt the hole FW with Androidtools in Parts and then flash all without misc like AvA wrote before.Maybe that could solve your Problem.
If you back a life always backup your Apps,do it like i wrote before,a half hour of work and all is like before and for Security TWRP Backup,
too!!!!
Please Report all Bugs you can find even bad or wrong Translations,so Ugoos Team can do their best.
Have a nice Day
gefattern
There are currently 2486 users online. 1 members and 2485 guests.
