The box have this S. No.: S0X23100101057
Beelink X2 DEAD!
Beelink X2 DEAD!
Hi, suddenly the box has shut down and is no longer divided ! The LED that is red in standby is off now . I tried a universal power supply but does not go either! I tried to flash with the phoenix , by inserting the USB cable after pressing for 4-5 seconds the reset button , but the pc does not recognize it and the box warms.... CAN IT BE SOLVED?
Tags: None
hey try this phoenix application. my box was seen as unknown device in windows device manager and many other versions didn't recognise the box this phoenix worked PhoenixPacketV400!!
I copy this from diferent topic on this board: you can take also this img firmware. On phoenix click firmware button and select your IMG firmware, than go to start and press start, on the box use tooth pick or something like this and press and keep pressing reset button on the bottom of the box (small hole), insert usb cable and press few times power button. you will see a big green rounded icon with tick when will start flashing. Do you have any light when you insert usb cable?
I have red but later after all procedure during flashing is green. good luck!!
Firmware 204K4
Build Number
4.4.2 KOT49H 20151229 test-keys
Vendor Software Version
204K4
Features:
1. Update Media Libraries;
2. Fix the Issue that some device's "spdif not active after system reboot;
3. Add 360XBOX support
https://mega.nz/#!O49lmazb!Q4yB7mxrz...u9XQ6cwvMYtKxw
OTA
http://mega.nz/#!X8VkERAC!oabuDkls-e...IRh8BXd5rq07Ug
PhoenixPacketV400
http://mega.nz/#!38kxBLrb!p_wrn72xyO...UiWquehbamFc_I
There are currently 2549 users online. 0 members and 2549 guests.
