Cenovo MINIPC2 Intel Cherry Trail Z8300 Windows10 Smart Mini PC 4G/64G 2.4G WiFi LAN HDMI 1080P OTG - Silver or Black
As soon as i get some free time will upload some pics internal and external as for aida don't want to stress the cenovo, and also my pipo x7 runs under pressure browsing,youtube playing at the same time, extracting some rars and generally doing some work around 60c even though it has changed thermal pads, heatsinks & a fan on the side so i am not really worried.
Originally posted by geoair.pt View PostHi all,
I just received a Cenovo MINIPC2 and would like to install windows 10 professional from a usb key but until now I've failed to boot from the usb key.
What bios settings must I change to enable boot from a usb key?
Thank you.
Regards
Then you will find Boot menu where you can set the boot drive
I'm having problems with my Cenovo Mini PC2, it is the graphics driver which is freezing. Does anyone have a working driver link? Or maybe a Double Driver saved drivers to share with us? As with other chinese companies, Cenovo support is virtually non-existant. Thanks in advance.
My english is bad, so i'm just trying to make this understandable. Cenovo minipc2 is just pure garbage! Mine had pirated windows 10, so i decided to install another os. The next problem was that bluetooth, wifi, and even sounds were not working (no drivers/support). I tried with ubuntu, kubuntu, elementary, mint, even tried with pirated windows 10 again but nothing! After days of fighting i finally contacted vendor and got link to chinese bullshit website and wasted a day to register and download some windows version, but still nothing... All this was months ago.
Yesterday i decided to try again to get this garbage working and i found linuxium website. I tried with Ubuntu16.10 Beta 2 and finally got sounds working, tho bluetooth and wifi are still not working (wifi worked with usb dongle). So now what i'm going to do is to order extra usb-wifi dongle and maybe also bluetooth and keep using ubuntu.
Aeolous thank you for that link, i'm going to save that file just in case!
Originally posted by naorsa View PostHello everyone
like to install windows 10 professional from a usb but until now I've failed to boot from the usb .
I know how to access bios pressing the ESC or F2 , But he does not see the drive Usb
I made a bootable usb with rufus
Thank you.
Use Rufus to generate a bootable USB stick formatted to FAT32 with 4096 bytes cluster size.
Insert USB stick into the mini PC.
Power on the mini PC and immediately repeatedly press F2 to access UEFI / BIOS.
From the first setting screen, select "Boot Manager" when subsequently the USB device should be selectable as the boot device.
In the meantime, this is what I found in power supply: https://i.imgsafe.org/c40eec3750.jpg
But outside power supply:https://i.imgsafe.org/c40a2b7bf0.jpgLast edited by naorsa; 10 December 2016, 18:54.
Originally posted by naorsa View PostIn the meantime, this is what I found in power supply: https://i.imgsafe.org/c40eec3750.jpg
There are currently 4299 users online. 1 members and 4298 guests.
