hph NT-V8 + Skype + Logitech c525
Anyone got the microphone to work on this? Video works, but I can not find where to enable the microphone...kind regards
cyber7 (aka Aubrey Kloppers; Cape Town; South Africa)
http://www.cyber7.co.za / http://aubreykloppers.wordpress.comTags: None
kind regards
kind regards
Hi mo123 Any chance you have looked at this?kind regards
Originally posted by mo123 View PostYes, will upload the fix for testing today.kind regards
kind regards
Please test if it works.
If not, I will make a new patch later.
The offsett is set to 1000 for flashing which should be correct for dual-boot and Android-Only firmware.
Mic Fix
https://drive.google.com/file/d/0B2J...ew?usp=sharing
Tips
When an incoming call is received, Skype will not make a ringing sound, maybe because of no cellular hardware.
Can check Skype settings but it might still not work.
Can also try to use Automate to play an mp3 when an incoming call is received.
If you make an outgoing video call, sometimes the outgoing audio doesn't work.
A workaround is to make an outgoing audio call, then turn on the camera, then the audio works.
Audio works correctly on incoming calls.
If there are still problems:
Make sure Google apps are updated.
Also Google voice is installed.
Also try using different USB ports or a USB Hub to plug the webcam in.Last edited by mo123; 05-20-2016, 06:42.
There are currently 2524 users online. 3 members and 2521 guests.
