Possible to make usb burn tool image from sd card files?
OK, reason being is that the only version that will unbrick my box is done via sd card. Now when I try to unbrick, the red light turns blue when power is applied with the sd card in but continues to show "no signal" on the tv. Before it would turn blue but start the recovery process. I'm thinking the uboot on the box might be messed up? BTW, it's a S805 V3_1 20161230. Was thinking I could convert those files to an image I could try with the usb burn tool.
Originally posted by abdul_pt View PostDon't know all from memory, but they are around 10 files. Split a image to seen
Tapatalked
Code:aml_sdc_burn.ini boot.PARTITION bootloader.PARTITION DDR.USB image.cfg logo.PARTITION meson.dtb meson8m2_n200C_1G.dtd meson8m2_n200C_2G.dtd platform.conf recovery.PARTITION system.PARTITION UBOOT_COMP.USB
boot.PARTITION
recovery.PARTITION
system.PARTITION
with
boot.emmc.win (from TWRP backup)
recovery.img (from this site)
system.ext4.win
,will I able to flash this via USB Burning Tool and boot into recovery?
Btw is there a way to extract bootloader.img from TWRP backup files? Thanks.
Code:boot.emmc.win 33,554,432 boot.emmc.win.md5 48 logo.emmc.win 33,554,432 logo.emmc.win.md5 48 recovery.log 240,701 system.ext4.win 913,044,992 system.ext4.win.md5 50 system.info 64
There are currently 2869 users online. 0 members and 2869 guests.
