Quick reference for first time KODI users.
    Starting KODI for the first time:
    Settings:
    • SettingsAppearance/Settings level/Advanced - Get advanced settings.
    • Settings/Appearance/International - Set your REGION. (I use UK(24h) gives 24H00 and Celcius)
    • Video/Acceleration - Un-tick "Allow hardware acceleration - MediaCodec (Surface)"
    • Weather/General - Enable/Install "OpenWeatherMap Extended" and choose your Location from "Settings"
    Addons/Install from repository:
    • Web interface - "Arch" - Give you access to the system from a Web Browser and this one is better.
    • Video add-ons - "Youtube" - Remember to authenticate.
    • Subtitles - "Opensubtitles.org" - Give you the best subtitles for foreign and hard of hearing support.
    • Services - "XBMC Check Previous Episode" - This one give you a popup to go to the first UNWATCHED TV show when you start an episode.
    • Services - "Watchdog" - This will update your library if a change is seen.
    • Services - "Unpause Jumpback" - This will jump back 10 seconds when paused for more than 10 seconds. Remember to set the "jumpback" value to 10 seconds...
    • Services - "Nextup Service Notification" - This will give you a netflix style button you can press to watch the next episode.
    Other Addons:
    • Program add-ons/Trakt - This will give your library access to TRAKT.
    • Music add-ons/Radio - Access to some nice radio-stations. You can also define your own streams.
    You can share/sync your library between more devices by adding a smb and mysql server into your setup. Refer to the KODI WiKi (http://kodi.wiki/view/Main_Page) for more info.
    http://kodi.wiki/view/Advancedsettings.xml:
    This is one of the most useful sites if you need to get custom settings into KODI. Refer to site for more info.
    In my environment I have the following advancedsettings.xml in place:
    <advancedsettings>
    <videodatabase>
    <type>mysql</type>
    <host>{IP}</host>
    <port>3306</port>
    <user>kodi</user>
    <pass>kodi</pass>
    </videodatabase>
    <musicdatabase>
    <type>mysql</type>
    <host>{IP}</host>
    <port>3306</port>
    <user>kodi</user>
    <pass>kodi</pass>
    </musicdatabase>
    <videolibrary>
    <importwatchedstate>true</importwatchedstate>
    <importresumepoint>true</importresumepoint>
    <dateadded>0</dateadded>
    <recentlyaddeditems>400</recentlyaddeditems>
    </videolibrary>
    <video>
    <latency>
    <delay>-250</delay>
    </latency>
    <playcountminimumpercent>90</playcountminimumpercent>
    <ignoresecondsatstart>180</ignoresecondsatstart>
    <ignorepercentatend>8</ignorepercentatend>
    </video>
    <network>
    <buffermode>1</buffermode>
    <cachemembuffersize>104857600</cachemembuffersize>
    <readbufferfactor>4</readbufferfactor>
    </network>
    <pvr>
    <minvideocachelevel>60</minvideocachelevel>
    <minaudiocachelevel>60</minaudiocachelevel>
    </pvr>
    <cputempcommand>echo "$(busybox sed -e 's/current cpu_temp://' /sys/rockchip_thermal/temp) C"</cputempcommand>
    </advancedsettings>
    So, as you can see the settings can be quite a handful, but it will help and make your life easy to read and understand how it works.
    kind regards
    cyber7 (aka Aubrey Kloppers; Cape Town; South Africa)
    http://www.cyber7.co.za / http://aubreykloppers.wordpress.com
    Settings? are these settings for Custom Kodi rk3368 based build or fresh install from play Store / apk form Kodi site? or Both?
    -RK3368 CSA91/R8/R68 V2, V4
    Latest Updated Firmware for CSA91 based on Zidoo Full/Lite (Working Hardware Clock) by krypton
