Ok, I solved the problem with the (RECOVERY TWRP)
I managed to install the ROM:
Beelink Mini MX (s905_105L1_sdcard.zip).
In the week I will explain how I did.
I installed the ROM (finless_remixos_1.0_S95_telos) in my BEELINK miniMX III, it worked well.
But, after a reboot, I've had, a Continuous boot logo.
Impossible to access recovery.
For the (RECOVERY TWRP), I install the ROM "ROOFULL MX64_MRX_0304_SD_card ".
Then I press the RESET button, plug in the power and then let go of the RESETbutton.
I continue to look for (RECOVERY TWRP), or boot SDCARD.
Oh, I've just found it. I didn't think that in the small hole is the reset button Thank you.
Could you tell me also which version of TWRP is correct for Beelink Mini MX III. I find this post:
Is your Beelink MiniMXIII shows now that it has 1 or 2 GB of RAM?
