Beelink Mini MXIII S905 Video Freeze
    Had my Beelink Mini MXIII S905 Box for a week now. Been really happy with everything up until I went into Kodi and tried to play a specific live video stream. The stream played fine for about 5 seconds but then the video froze and the audio continued fine. I tried this with several other live streams from the same category and the same happened on all of them. I then went an tried some other live streams from another category and they all worked fine. This led me to believe it was either an issue with the streams or the type of video/audio I was trying to view. I plugged my old PIPO X6 RK3288 box in and tried the same streams and everything was working 100% so ruled out the issue with the stream itself.
    Okay this is where my technical knowledge ends but must be the type of audio/video of the stream I'm trying to watch? If this is the case, two possible routes:
    (1) Change a setting (quite likely as I tweaked a few to make my audio work - I use a SPDIF to my surround sound), but what do I need to change?
    (2) Maybe this new box can't handle the stream (doubtful as it is a new S905 and my old RK3288 was fine) but how would I test this/what do I look for?
