Please Identify my device R68-1GB
    Please help me out to identify my Generic device for correct/stable/fast stock/custom roms and any fixes for device to play around before i buy some good stuff
    pre installed KODI old version 15.1 with tvaddon build which is really sluggish.
    Thanks in advance Click image for larger version
    LINKS TO IDENTIFY PICTURES AND SPECS
    http://m.dhgate.com/product/r68-andr...376130222.html
    http://ru.aliexpress.com/store/produ...storeId=903733
    http://wesopro.manufacturer.globalso...oid-TV-Box.htm
    http://www.****.com/itm/R68-Android-...-/301833201210
    FLASHED TWRP RECOVERY. BACKUP TREE OF FIRMWARE:
    D:.
    └───TWRP
    └───BACKUPS
    └───CSA90
    └───2011-01-01--11-47-49_rk3368_box-userdebug_5.1.1_LMY48G_eng.root
    boot.emmc.win
    boot.emmc.win.md5
    cache.ext4.win
    cache.ext4.win.md5
    cache.info
    data.ext4.win
    data.ext4.win.md5
    data.info
    internal_sd.info
    internal_sd.vfat.win
    internal_sd.vfat.win.md5
    kernel.emmc.win
    kernel.emmc.win.md5
    misc.emmc.win
    misc.emmc.win.md5
    recovery.emmc.win
    recovery.emmc.win.md5
    recovery.log
    resource.emmc.win
    resource.emmc.win.md5
    system.ext4.win
    system.ext4.win.md5
    system.info
    trust.emmc.win
    trust.emmc.win.md5
    uboot.emmc.win
    uboot.emmc.win.md5
    SOME INFO FROM DEVICE (AIDA64):
    Manufacturer: rockchip
    Model: rk3368-box
    Brand: Android
    Board: rk30sdk
    Device: rk3368_box
    Hardware: rk30board
    Product: rk3368_box
    Serial: IYIACCI8W0
    Installed RAM: 1 GB
    Total Memory: 991 MB
    Available Memory: 272 MB
    Internal Storage Total Space: 2975 MB
    Internal Storage Free Space: 1906 MB
    External Storage State: mounted
    External Storage Total Space: 2915 MB
    External Storage Free Space: 2021 MB
    Device Features: android.hardware.audio.low_latency
    <<< CPU >>>
    SoC Model: RockChip RK3368
    Core Architecture: 8x ARM Cortex-A53 @ 1512 MHz
    Manufacturing Process: 28 nm
    Instruction Set: 64-bit ARM
    CPU Revision: r0p3
    CPU Cores: 8
    CPU Clock Range: 312 - 1512 MHz
    Core 1 Clock: 600 MHz
    Core 2 Clock: 600 MHz
    Core 3 Clock: 600 MHz
    Core 4 Clock: 600 MHz
    Core 5 Clock: 600 MHz
    Core 6 Clock: 600 MHz
    Core 7 Clock: 600 MHz
    Core 8 Clock: 600 MHz
    CPU Utilization: 10 %
    Scaling Governor: interactive
    Supported ABIs: armeabi-v7a, armeabi
    Supported 32-bit ABIs: armeabi-v7a, armeabi
    AES: Not Supported
    NEON: Supported
    SHA1: Not Supported
    SHA2: Not Supported
    <<< Display >>>
    Screen Resolution: 1920 × 1080
    xdpi / ydpi: 160 / 160 dpi
    GPU Vendor: Imagination Technologies
    GPU Renderer: PowerVR Rogue G6110
    Refresh Rate: 61 Hz
    Default Orientation: Landscape
    OpenGL ES Version: 3.1
    GPU Version: OpenGL ES 3.1 build 1.4@3632227
    OpenGL ES Extensions: GL_EXT_debug_marker
    << Wi-Fi >>
    State: Enabled
    SSID: xxxxxxxxxxxxxxxxxxx
    BSSID: xxxxxxxxxxxxxxx
    Hidden SSID: No
    IP Address: xxxxxxxxxxxxxxxxxxxx
    MAC Address: xxxxxxxxxxxxxxxxxx
    Signal Strength: -45 dBm (Excellent)
    Link Speed: 150 Mbps
    Frequency: 2437 MHz
    Network ID: 0
    Gateway: xxxxxxxxxxxxxxxx
    DNS1: xxxxxxxxxxxxxxxxxxx
    DHCP Lease Duration: 24 hours
    5 GHz Band: Not Supported
    Wi-Fi Direct: Supported
    <<< Android >>>
    Android Version: 5.1.1 (Lollipop)
    API Level: 22
    Rooted Device: Yes
    Android ID: af7e1fad1c6a3a6e
    Build ID: rk3368_box-userdebug 5.1.1 LMY48G eng.root.20151014.134753 test-keys
    Codename: REL
    Fingerprint: Android/rk3368_box/rk3368_box:5.1.1/LMY48G/root10141351:userdebug/test-keys
    Incremental: eng.root.20151014.134753
    Java Runtime Version: Android Runtime 0.9
    Java VM Version: ART 2.1.0
    Java VM Heap Size: 192 MB
    Kernel Architecture: aarch64
    Kernel Version: 3.10.0 (edwin@ubuntu01) (gcc version 4.9 20140514 (prerelease) (GCC) ) #281 SMP PREEMPT Wed Oct 14 14:04:05 CST 2015
    Tags: test-keys
    Type: userdebug
    Google Play Services Version: 9.0.83 (230-121911109)
    OpenSSL Version: OpenSSL 1.0.1j 15 Oct 2014
    -RK3368 CSA91/R8/R68 V2, V4
    Latest Updated Firmware for CSA91 based on Zidoo Full/Lite (Working Hardware Clock) by krypton
    i guess everyone on the group like me not a single answer. well I have found CSA91 firmware is 100% compatible for the above device if anyone else is on the same boat. By the way what is the most stable KODI custom build for RK3386 if anyone like to answer. The current build comes from the firmware as well Superceleron Kodi videos are jerky felt like skipping frames. no bandwidth problem from my end.
      I am using NTMC by mo123 on my Tronsmart R68. Works very well. You can also try SPMC, ZDMC and Rockchip Kodi. Good luck..
      Tronsmart Orion R68 Meta
      CS968 -> HTC_T018 v4 20131216 with MTK
      GM282 (aka CX 919 II aka J22) - dead
        Haven't tried NTMC yet. SPMC No more Rockchip specific support (on there site) . Tested ZDMC version 16.0.2 seems to work fine 16.0.5 crashes on start. What is ROCKCHIP kODI?
        Can you provide any links ? It seems that kodi future for RK chips is not very bright.
          Its Ok Surprise coming soon 😁😁😁😁
            SPMC 14.2 or earlier will work well. Rock chip is working on its own version of Kodi since Kodi team has announced no more support for it. Wait for scooters surprise 🙂
              FreakTab surprise coming i think everyone will be happy about it. JD/Neo/ Will post when something to say 😁
                I love Surprises
                  Making me more curious 😀 Is it a freak tab surprise? I thought it was from Rockchip?
                    Yes new surprise come next week as i said i think it make alot happy. 😁
