Dead Tronsmart R68G :(
    Hello,
    My sister accidentally connected a 12v 2A power adapter to her R68G
    now it wont start, there is no lights and it seems it's DEAD.
    when we opened the BOX it looks that the board is OK, it is now burned and it looks brand new.
    is there anything we can do to fix it? is it possible that only the power connector is damaged?
    Bye Bye R68G may you R.I.P.
      In that case, I offer my condolences.
      Having several boxes around, I label every power adapter's connector.. I don't want to kill one that way. I prefer to kill them by flashing incorrect F/W or other means.
        Most devices jave one cap connected to the power supply check to see if you can locate abd cut off and attach a similar cap.... Nothing to lose at this point 😃
          OK, tnx
          i will try that
            zivco Hello! you have fix power supply? ...have same problem... mother connect 12V
            have found MOTHERBOARD... (4608x3456)
            TRONSMART R68: Firmware "HPH NT-V8 ROM V1.2 (Dual-Boot) by mo123" (DTS-HDMA, Work)
            ONKYO: TX-NR 809
              Help... ;-(
              ONKYO: TX-NR 809
                Hi, there is a fix to this problem
                you need to transfer the power throw the USB, here is more info:
                http://forum.tronsmart.com/forum/tro...start=12#14923
                Where to buy the adapters:
                ​​​​​​http://www.****.com/itm/351541096499
                ​​​​​​http://www.****.com/itm/322268069783
