Q Box s905 2gb/16gb - Stock Firmware request
Hi,You can download Android 5.1 from here
The title says its android 6 but they made a mistake its Android 5.1 not 6
Originally posted by nik1975 View Post
Thank you i ll give it a try.
This is a non root firmware am i right?
Sent from my iPad using Tapatalk Pro
No I don't no of any at the moment but you could try this EZ unroot zip
Iv not tested it on the Q box so at your own riskLast edited by blinkone; 15 February 2018, 16:12.Please consider making a Donation to freakTab
This one didn't work. Is there other fie which is tested ? I installed AM1 6.0.1 and after that my wifi and ethernet both not working. So I thought to restore the stock firmware but can't find the stock firmware. I installed so many S905 firmwares but the wifi didn't turned on, though the ethernet working on all previous 5.1.1 but wifi is not working. Can anybody help how I can fix this ?
did you already tested the Rom of Superceleron for this Box ???
greetings / gefattern
Yes I also installed the super celeron rom but that didn’t work either. Now I believe that the WiFi binary is corrupted. Though I also made a dump from trwp and restore the dump but that didn’t work either. I have another Q9 box which is 1G / 8G, so I made the stock dump and restored it on this faulty 2/16g box. Any other advises shall be highly appreciated.
Originally posted by haseebali View PostYes I also installed the super celeron rom but that didn’t work either. Now I believe that the WiFi binary is corrupted. Though I also made a dump from trwp and restore the dump but that didn’t work either. I have another Q9 box which is 1G / 8G, so I made the stock dump and restored it on this faulty 2/16g box. Any other advises shall be highly appreciated.
but why u ask here , here is for QBox 2/16 , please open up and look for the WifiChip then ,
maybe we can guide you to a working Rom , Pictures of PCB , nearby , good light , both sides ,
would be good to help ,
I am afraid to open the box as the box is sealed from clips which I believe doesn’t made of good quality plastic quality. One more question how do I install the Xbox 360 wired controller ? I did tried the system/usr/key layouts procedure but that didn’t work either, any other advises ? Thanks
There are currently 6191 users online. 1 members and 6190 guests.
