If you want to add cooling you can use wassers rom but without cooling it will fail.
Moe123 hph /mk902ii v6
There is a way to bypass the slow mem and use the fast sd card as system allowing a 32 gig system memory and this does work much faster then the device memory.
If you want to add cooling you can use wassers rom but without cooling it will fail.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
RKM told me the latest code they have is 201603 end of last year and that is too old to be compatible with the latest HPH/Firefly RK3288 firmware that had lots of new code in the kernel, system since.
I don't have 2 weeks full time to try to port the remote, power drivers, fix booting problems etc. to a newer kernel and firmware.
The videos stuttering is because on the RKM, it uses much slower clock rates for the RAM, CPU than on other devices, because the box is much smaller, more things are closer together and not enough cooling and a small heatsink is installed. For smooth 1080p/4K, RAM needs to be 533mhz speeds but is about 400/433mhz on the RKM RK3288. The storage chip also plays a big part because all the streaming media is saved to it and the RAM while playing. The storage chip is about 30-40% slower than on other RK3288 devices and that is not something you can fix by software. When flashing the RKM RK3288 it takes about twice as long as on my other RK3288 devices because of the slower storage(EMMC).
To reduce stutter, try to not run any background services, also keep only a few apps installed.
Ugoos ut3 new firmware runs well on this device. Sd card fast one it runs fast smooth and no heat issues. Confirmed working. Wifi/bluetooth/ sd card/ usb ports one not working. Have not checked network but think it wont from past tests. Seems to run nice. Will duve into it more tonight. Just loading it up with everything lol.
Network work too....
Sd card samsung 32 gig pro get clise to 50 antutu box sd close to 35 so is better on sd card. But works fine on the box as well.
doesnt heat up on sd card but does get very warm on nan.Last edited by scooter2014; 09 March 2017, 04:47.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
Originally posted by scooter2014 View PostUgoos ut3 new firmware runs well on this device. Sd card fast one it runs fast smooth and no heat issues. Confirmed working. Wifi/bluetooth/ sd card/ usb ports one not working. Have not checked network but think it wont from past tests. Seems to run nice. Will duve into it more tonight. Just loading it up with everything lol.
... whoa, what's the reason for the difference in performance? Is it i/o and memory score that's higher?
Low emmc in mk902ii is why low on nan. But just flashed on with regular rk tool sd card made with lithium boot from sd card in linux. ( boot from sd card second method with script. )
Dont own v5 so dont know why doesnt load. Did you download ut3 not another device? Others got working in 3288 devices so know it works.Many devices now mk902ii/Shield/Mk68 /Ugoos/neox5/minix5 (yes they still work lol) mk80 no it doesnt work lol.
There are currently 1925 users online. 1 members and 1924 guests.
