STUCK IN ROM MASK MODE
    I have a 802 mkiiis BT ap6210 that was bricked after bad cwm update attempt. Then I tried to flash with windows 10 with rkbatchtool v1.8 and success. But blank screen after boot.
    So I tried flashing with image from this site and flash failed. Device booted same as before
    I tried re-flashh but not detected. Now put back in ROM mask shortening 5-6(San disk nand) back in ROM mask erase idddb twice but can't flash
    Stuck in ROM mask mode
    Any ideas? Tried rock chip SD tool and copied image but won't update.
    Hello,
    Question is what Version you want to Flash Android 4.4 ?
    What Firmware you got before on the Stick?
    Neomode
    Gesendet von meinem Redmi Note 3 mit Tapatalk
      Neomode it was stock 4.2.2 jb
      Then I screwed up by first trying cwm update.zip followed (stuck cwm loop) by using non dta USB cable SSSI I used short pin method
      Recently I used rk batch 1.8 and flashed rkm''s 4.2 but tool said it was 4.1? Think it was wrong firmware because ap6210 to new?
      So first boot it mounts SD/internal/recovery, robot spins then boot logo then youuu see splittt second start screen then black screen
      Tried to do another ROM flash fail led after saying lower leveL format but stick still booted
      Tried flash neo mode ROM but stick not recognized
      Before remembering to try change 0 to 1 in tool I panicked and entered ROM mask mode severaaal times before changing the 0/1
      Now booth tools see stick stuck in ROM mask mode but won't flash
      I just want any stable 720p ap6210 802mkiiis roooom and how can I get out of ROM mask mode?
      Thank Thank Thank yoiu
        Can you please make a Photo of your Device?
        Neomode
          Piics Click image for larger version
ID:	575194 Click image for larger version
ID:	575195 Click image for larger version
ID:	575196 Click image for larger version
ID:	575198 Click image for larger version
ID:	575197 Click image for larger version
            Piics
              Have tried stock ROM flash after clearing IDB twice IDB fails stuck in ROM mask mode need help
