Android TV BOX
    Android TV BOX
    Dear neomode,
    Can you help me regarding a android tv box Android 4.4 Quad-core ARM Cortex-A7 1.3GHZ, memory 1GB DDRIII, 8GB Nand Flash, WiFi
    It got stocked while playing youtube, for my doughter on tv.
    I have disconnect it once from power, and then Android sign was there for a while. Then I tried to do a hard reset, but the logo with No Command appeared, and it did not move forward.
    I also tried to flash it ( but could not find a right firmware ) but nothing.
    Now the red light appears immediately when I connect it with computer.
    I will attach some photos of it
    Many thanks
    ​Xeni
    Can't upload photos, will try again
      Yes please do it.
      Also if you can from the Inside that we can find a Firmware.
      Never hear from that Device.
      Neomode
        This is the only choice
          Now that is connected with USB cable, and red light is on
            Yes right Light means Power on that´s all.
            We need to find a New Firmware for this Puppy.
            I am on it...
            Neomode
                Dear neomode
                After some playing with this tv box, I lost the driver, BUT I was able to bring it back connecting PIN 8+9 at SK Hynix....
                  Dear neomode,
                  Now, I can connect it with pc, but there is another problem with Download Boot Fail....
                  Is there any way to bring back Boot?
                  Xeni
                    This is what I get from these tools........
                      Anyone can help with this issue?
