Some details about it:
Fix (disable) power saving mode on RTL8812AU chips
Fix minor issues with SSL certificate paths
Fix for an EPG search issue (backported from Krypton)
Fix machine-id uniqueness on hardware with slow-loading network drivers
Fix boot splash aspect ratio on nVidia GPU systems
Update Kodi RPi-backport patch to address minor Kodi video issues
Update the LibreELEC add-on repo to use gzipped addons.xml
Add support for the Netgear WNA1000M v2 to RTL8192CU
Add support for bluez auto-pairing with DualShock3 controllers
Add LibreELEC RSS feed to Kodi (RSS remains off by default)
The links for instalation:
For NAND:
http://releases.libreelec.tv/LibreELEC-WeTek_Core.arm-7.0.1-update.zip
http://releases.libreelec.tv/LibreELEC-WeTek_Core.arm-7.0.1.img.gz
http://releases.libreelec.tv/LibreELEC-WeTek_Core.arm-7.0.1.tar
