LibreELEC 7.0.1 for WeTek Play/OpenELEC
    LibreELEC launched a new version with some changes comparing with the 7.0.0 version:
    Some details about it:
    Fix (disable) power saving mode on RTL8812AU chips
    Fix minor issues with SSL certificate paths
    Fix for an EPG search issue (backported from Krypton)
    Fix machine-id uniqueness on hardware with slow-loading network drivers
    Fix boot splash aspect ratio on nVidia GPU systems
    Update Kodi RPi-backport patch to address minor Kodi video issues
    Update the LibreELEC add-on repo to use gzipped addons.xml
    Add support for the Netgear WNA1000M v2 to RTL8192CU
    Add support for bluez auto-pairing with DualShock3 controllers
    Add LibreELEC RSS feed to Kodi (RSS remains off by default)
    The links for instalation:
    For NAND:
    Code:
    http://releases.libreelec.tv/LibreELEC-WeTek_Play.arm-7.0.1-update.zip
    For mSD card:
    Code:
    http://releases.libreelec.tv/LibreELEC-WeTek_Play.arm-7.0.1.img.gz
    For Update (OpenELEC or LibreELEC)
    Code:
    [URL="http://releases.libreelec.tv/LibreELEC-WeTek_Play.arm-7.0.1.tar%5b/code%5d%5b/QUOTE"]http://releases.libreelec.tv/LibreELEC-WeTek_Play.arm-7.0.1.tar[/URL]
