Ugoos UT4 - New Firmware Posted...
Thanks for the heads up. Just installed it on my Tronsmart R68 non-gigiabit version. Excellent Rom, everything works great, My WiFi, bluetooth and Ethernet work. Their Kodi mod gives me HD audio. I will strongly recommend Ugoos.
I made a video on how to port different firmwares to different Rockchip boxes, in case some one doesn't know how to do it.
Originally posted by [email protected] View PostI update my Z68 TV box with this new FW, the remote control function does not appeared to work with Z68 stock remote control. I backed it up with TronZid-v9-2.
Does any body have the same issue? or I did something wrong.
Thank you,
Ask the manufacturer of Z68 for updated firmware or get a Ugoos UT4 then you won't have any problems.
Thank you,
Z68 remote only works with Nagrace HPH and Zidoo X6 ROMs.
There are currently 3673 users online. 1 members and 3672 guests.
