I have bought this device for my kids to watch cartoons (i have got 3 little ones): http://www.aliexpress.com/item/DLP400/32476276912.html
It worked ok for Youtube Kids and Netflix for a while up until one day it stuck at boot Android logo and did not go further. I tried contacting the seller, but he just said reset the device with the reset button. Same same. After that just stopped responding so I thought I try my best.
Could anyone help to find a good firmware to see if I can unbrick it?
CPU: RK3188-T WIFI: AP6330 DLP: DPP2607 Board: OP53_V22 2015-08-03 1534
I will attach some photos of its inside. Hope that helps.
Thanks in advance for looking at this. Item specifics
- Time to market:2015
- Style:DLP
- Brightness:4000 Lumens
- Light Source:LED
- Projected Dimension:20-300 inches
- Projective Mode:Throwing, Back Projection, Desktop, Ceiling
- Max Resolution:800*600
- Keystone Correction:None
- is Pocket Projector:Yes
- Lamp:OSRAM LED lamp
- Zoom:x 1.5
- Contrast Ratio:3001:1-4000:1
- Lens:Manual lens
- Resolution:854*480 Native
- Projection Technology:DLP
- Portable:Yes
- Screen Scale:4:3/16:9
- Use:Business & Education,Home,Engineering,Portable Projector,Pico Projector,Commercial Projector,Business Teaching Projector,Entertainment Projector,Game
- Home Theater Projector:Yes
- Type:Digital Projector
- Projection Distance:0.5m-2.5m
- Optical Resolution:854x480dpi
- Model Number:DLP 400
- Weight:250g
- Bluetooth:Bluetooth 4.0
- Projector built-in technology:Build-in Android 4.4 + Wifi
- Ram Flash:1G+8G
- Battery capacity:3200mAh
- Power adapter:5V 2.5A
- Speaker:Built in 2Wx2 (5.1 Dolby Surround Speaker)
- Feature:Mircast for Android , AirPlay for IOS
- CPU + GPU:4 core CPU + 8 core GPU
- Free gifts for every order:Mini Tripod
- Multi Language and power plug:Yes
