Mxq Pro Plus Rom issues
Originally posted by wolfheart79 View Postits the same rom of the Russian forum and have the same error of my older post
Hi Wolfheart - I made this thread so issues can be posted. So Devs dont have to search all over to see what the issue is as well as presenting area where Gearbest can send to Manufacture. So post away present detailed issues and let everyone know what does /doesnt work so hopefully someone can look into it.At the least its out there for your use.
Use this method:
I had previously bricked my MXQ Pro + 4K S905 2GB/16GB with a bad flash. I bought this box from Everbuying (http://www.everbuying.net/product1164624.html). It would hang at the Bootscreen logo and the toothpick method had no response when attempting to boot into recovery mode while plugged into the TV.
http://freaktab.com/forum/tv-player-...188#post572188
I was finally able to recover the box!
Get a Male to Male, USB-A to USB-A cable to plug the box into your computer.
http://www.amazon.com/C2G-Cables-541.../dp/B003VTZ07U
Download and install USB Burning Tool 2.0.7
https://mega.nz/#!04EDWDLQ!EGJM1sFU2...NgjFan0fzTxQRs
Original source link http://aml.technikexpert.com/amlogic...v2.0.7_x86.rar
(I can't seem to find where exactly I found this particular version, I've spent hours over several days attempting to recover the box and have lost track of that particular tab)
Download Firmware .img file (aml_upgrade_package0429.img)
https://mega.nz/#!JtFRTLAT!XE2m7cmuW...3Dpj6OTMFvBK3c
Sourced from http://freaktab.com/forum/tv-player-...878#post573878
Launch USB Burning tool 2.0.7
-Select the second drop down menu and select English
-Plug one end of the USB cable into your computer
-(Do not use the power cable for the box, It can boot and run off of just the USB cable) Use the toothpick method to press the reset button inside of the AV hole in the back and plug the other end of the USB cable into USB-4 on the MXQ box (This is the only port that allowed USB Burning Tool to recognize my box) It only took a couple seconds for USB Burning tool to recognize my box. You can then release the reset button.
-Select the File drop down menu and select "Import Image"
-Select "aml_upgrade_package0429.img"
-Click the "Start" button (I did not change any settings, the erase flash/normal erase and erase bootloader check boxes were already selected)
-After 5-6 seconds the timer stopped and I received an error message stating something about the bootloader (sorry I forget exactly what it said) Do NOT hit "STOP" or anything else!
-Unplug the MXQ box and Plug it back in while holding the reset button with a toothpick again. At this point the USB Burning Tool should automatically restart the install sequence and complete it without any errors. It took about three and a half minutes with my computer. When it was done I simply unplugged it from the computer and hooked it up to my TV.
I have the box hooked back up to my TV in what appears to be full working order.
wolfheart79,
Use the recovery method I posted. I ran into the same issue.
http://freaktab.com/forum/tv-player-...=1464808391184
I successfully flashed TWRP to my MXQ Pro +.
First I rooted my device with this method.
Source: http://freaktab.com/forum/tv-player-...ll-s95-devices
Download .zip file.
https://drive.google.com/file/d/0B9B...ew?usp=sharing
Unzip and place all three files on a SDcard
ezroot.zip
recovery.img
factory_update_param.aml
Insert SDcard into MXQ box with it powered off. Power on device with flash drive in place.
Go to "My Apps" and run "Update & Backup".
Click on "Local Update" and click on "Select". It should find ezroot.zip on your SDcard.
Select eztoot.zip and update.
The box will reboot and will be fully rooted!
Play store on our boxes does not allow you to install alot of apps because it says they are not compatible with the device. To solve this I downloaded the Aptoide .apk, copied it to a sd card, and manually installed the app using App Installer. Aptoide bypasses the Play Store and allows you to install any app regardless of it's designated compatibility with your device.
Download: http://pool.apk.aptoide.com/1/AptoideTV-2.1.1.apk
Sourced from: http://m.aptoide.com/installer-aptoide-tv
I then used Aptoide to install Rashr - Flast Tool.
Rasher on Play Store: https://play.google.com/store/apps/d....recoverytools
Download the TWRP .img (TWRP3_VegaS95_Meta.img)
Download: http://www.freak-tab.de/abdul_pt/aml...gaS95_Meta.img
Alternate Download: https://mega.nz/#!x5N3TTpD!jzcV-_x1Z...YwJ7G0qkIlsNIU
Source: http://freaktab.com/forum/tv-player-...mlogic-devices
Copy the .img file to a USB or SDcard and insert the card into your MXQ box.
Open the Rashr app
Using the mouse function on my remote I selected "Recovery from storage"
Select the top option "/storage/emulated/" to move up a directory
Select the top option "/storage/" to move up a directory
Select one of the "udisk" or "sdcard" options depending on which media type you used and which slot it is in. ("sdcard1" was my SDcard slot)
Select "TWRP3_VegaS95_Meta.img". A prompt will appear asking you to confirm, click yes.
Reboot into recovery mode to find a functional TWRP.
***Note*** TRWP does not seem to recognize USB drives or SDcards
***Update*** I was messing around and had to reflash the box, I used the aml_upgrade_package0429.img. This time TWRP did recognize the SD card right away
The recovery button inside the AV port still does not work to boot into recovery so I installed Recovery Reboot to have a easy way to reboot into recovery mode.
Play Store Recovery Reboot page: https://play.google.com/store/apps/d...ecovery.rebootLast edited by zippy611; 03 June 2016, 20:06.
Originally posted by zippy611 View PostI successfully flashed TWRP to my MXQ Pro +.
Source: http://freaktab.com/forum/tv-player-support/amlogic-based-tv-players/s905/tronsmart-ac/firmware-roms-tools-at/544216-new-ez-root-zip-for-all-s95-devices
Download .zip file.
Unzip and place all three files on a USB or SDcard
ezroot.zip
recovery.img
Insert USB or SDcard into MXQ box with it powered off. Power on device with flash drive in place.
Click on "Local Update" and click on "Select". It should find ezroot.zip on your USB or SDcard.
Open the Rashr app
Play Store Recovery Reboot page: https://play.google.com/store/apps/details?id=gt.recovery.reboot
MIne box successfully flash TWRP recovery as your method, but the problem is as it can boot to recovery using the toothpick method, so look like that this box can't connect to Amlogic burning tool any more. After using toothpick burning tool announce connected but after a minute it disconnected <= no more burning tool. How do we solve it?!? Anyone have the original recovery.img, can we re flash this one for working burning tool again?!?
Just copying this here as it seems related.
Don't bother trying to upgrade if your box is working. This was posted by floppymaster:
I just installed it, but it is a big disappointment.
First the installation process using the USB Burner Tool: You need a male USB to male USB cable. I experienced a lot of difficulties applying the patch. Luckily http://freaktab.com/forum/tv-player-...-16gb-recovery was quite accurate in describing how to flash. Make sure you have 2.0.7, it did not work with an earlier version for me. I needed to reconnect the device 3 times during the flash procedure due to errors which was very troubling, but in the end I had a 100% flash.
I had my hopes up but alas:
- Error messages about app crashes appearing when starting
- Still no top or bottom toolbars!!
- Very awkward default user interface.
- Google Play crashes when trying to search for something (while typeing the query).
- I can access my previously installed apps (from other devices) through Google play without it crashing, but when I try to install the ones of interest, I receive an error message stating that the application is not compatible, e.g. Netflix.
- There was no sound in Kodi or in Chrome. The only sound I heard was half of a notification sound for a new mail coming in. When opening the mail app I receive a warning message that Google Play services are not compatible with the device.
I wonder what issues have been addressed with this rom exactly... It is still unusable as far as I'm concerned.
HK1 Pro Plus
FlowFon F1
H96 Pro+ (Wisdom-Green Board-2017-02-10 H96-S912-TVBOX(DDR4)-V0.2)
MXQ Pro+
R-TVBOX Mini+
MK809III
Originally posted by kenblat View PostThanks for such detail sharing! Hats off!!!
recovery.img for aml_upgrade_package0429.img original firmware created with Rashr
Download: https://mega.nz/#!wg800DCb!M5fZxWy6Y...60TwDnHRXa7bIc
***UPDATE*** Flashed TWRP with Rashr, tested TWRP as working, Flashed the above posted recovery.img with Rashr, recovery appears to be back to stock and USB Burning Tool allowed me to perform the full recovery using the aml_upgrade_package0429.img.
******UPDATE***** Corrected Download LinkLast edited by zippy611; 03 June 2016, 20:07.
There are currently 4444 users online. 3 members and 4441 guests.
