Password: !Qyf61LTqgARUUaW9k2bB7A
Mini MXIII Stock Firmware
My Beelink MX III loaded up once and when I restarted it, it went into a boot loop - can I load this and see if it fixes it. I've tried the reset button on the bottom with and doesn't fix it. Just activates the HDMI signal - that's all I see. Did nothing special to cause this, so at a loss - I have about 3 Android devices and this is the first one that has failed.....
If so, can someone point me to how to do this.
I've considered RMAing it, but the cost of sending it back and then getting it fixed / replaced is probably more than getting a new one.
I installed the firmware "MINI MXIII_107L1_0425", does not work for me.
I' reinstall the firmware "MiniMX-G-107L1" with the methode "USB Burning Tool 2.0.7" , ok and all is well.
Link : http://freaktab.com/forum/tv-player-...nk-mini-mx-iii
Someone tried this method on minimxiii to boot images from sdcard?
http://freaktab.com/forum/tv-player-...thod-and-files
edit: I have just checked... yes, it works fine.Last edited by smarteswarm; 04 June 2016, 01:14.
Thanks for uploading the firmware. I'm not quite sure how to install it? It's not a regular img file?
I installed the one above from Moulin1980, for the MiniMX-G, which works, but it's not the same one that came from stock. Is yours the one that came stock on the box?
Originally posted by markv View Post
Hey gap300789,
It is a zip to use in 'update & backup'
I have a TWRP backup of the stock rom I could upload if anyone needs it
There are currently 3846 users online. 1 members and 3845 guests.
