M8S bricked, only RED light
    i know that your box is clone so the rom is android 4.4 but i search in freaktab forum and i found a similar board like yours that saw with android 4.4 and the box was unbricked with android 5.1.
      I was curious, so I tried today, all ROMs - your suggestions is not working, still 2% error...., if you have any other, shoot...
        tani,
        try this : http://freaktab.com/forum/tv-player-...683#post576683
          mandepsi your android box is the same like sappy or you have another M8S box ?
            sappy Try mandepsi link.I saw the mandepsi post about 8 hours ago but the problem is that your board looks like have broadcomm bcm 4335 wifi chip not AP6330 wifi chip
              Tried all.., but no luck...!!! ...., so frustrating...., new day today..., now going to sleep...., thanks for effort..
                try this rom https://mega.nz/#!bJEQjaIA!6y0fZsCEU...oSzGAimz46FNKc
                  dont worry sappy i will find the solution.hope that your nand internal memory chip is not demaged.I will write again.I will explain the nand short pins later.Maybe the rom is okcyx_m8s_v8.6_ap6330_8g2g_kodi_addons_ota_150908_ US B but you need to short nand pins 29 and 30.i will post a schema and the photo of pins to short
                    how do you use usb burning tool?
                    did you tried with "erase all and write bootloader"
                      Data on the other side of PBC:
                      5215
                      TEAN E120339
                      94V-OML1
                      and zoomed picture maybe helping to someone who saw a similar or the same board
                        Trust me..., I tried every combination..., but...
                          try this rom with usb burning tool https://drive.google.com/file/d/0Byi...p=docslist_api
                            and this other rom https://drive.google.com/file/d/0B24...NUb3VtTWc/view
                              the 2 last rom are able to unbrick M8 and M8S clone box.You have clone box .In your board is writen S812_M8 (8bit) v02 that looks like you have M8 clone box but i see that structur of your motherboard looks like M8S clone box.
                                you can exept that all roms works for your box becouse is the clone box.Hope that this 2 last rom that i have posted unbrick your android box
