ROMCUSTOM Superceleron on "BEELINK MINI MX III"
    hi all, I tested ROMCUSTOM of the Superceleron on "BEELINK MINI MX III".
    It is the best ROM now for me.
    Link : http://freaktab.com/forum/tv-player-...=1465078659699
    - works very well
    - super fast
    - remote controle = perfect
    - LAN ETHERNET = perfect
    - ROOT and TWRP included
    - just wifi = does not work
    Changelog Superceleron v1.0:
    • Build from the source.
    • Custom Kernel.
    • Proper rooted.
    • Twrp recovery. (thks abdul_pt/me)
    • Custom Kodi 16.1 RC2 Build.
    • initd.d support.
    • Debloated.
    • Xbox 360 cable and wireless support.
    • Network tweaks.
    • Permissions fixed.
    • Xposed Framework added and fully working.
    • Removed non working OTA.
    • Sleep working, full poweroff also working.
    • Google core framework updated.
    • Media reported free space fixed.
    • And other fixes i just cant remember!
    Be careful if you change the firmware, there is no stock firmware (.IMG) for beelink mini MX III ( for the moment).
    can you confirm that refresh rate can be fixed or automatically adapted ?
    Any sound stuttering on DTS passthrough ?
    thanks
      Hello,
      sadly, i've an issue on my minimxiii from beelink with your rom.
      If i use kodi, i have to stay on stereo to have sound, when i put my real set-up (5.1), i've no sound at all in kodi)
      Mx player works fine.
      any idea ?
        - works very well
        - super fast
        • Custom Kernel.
        • Proper rooted.
        • initd.d support.
        • Debloated.
        • Network tweaks.
        Do u have 2gb ram with this rom ?
          I have tried this rom and, aside from the lack of wifi, I found that Bluetooth doesn't work and, much more annoyingly, apps are killed when I go back to the launcher. So, I cannot download in the background, listen to Spotify etc.
            Is it possible to keep apps live, and not to be shut down like on mobile phone, for example, when i play youtube and go home, and then back to youtube to remeber were I left app?
