CX-919 some questions and issues.
    Hi all.
    I have most of my purchased apps downloaded on my CX-919 device. I seem to have a problem with the mouse that I'm using. When I single click on an option, button, etc... there is no response in a couple of apps. The mouse can move the cursor fine, but the mouse click doesn't work. Now, 90% of the apps and Android itself work fine with the mouse and clicking an icon, link, button, etc... So, I wanted to ask if this is a known issue with some apps, and if so, is there a way to resolve it? There are two apps of the many that I have that have this issue. They are Aralon and Ravensword: Shadowlands.
    The next question is on apps not fitting properly on the HD TV screen. Is there a way to force apps to retain their proper visual aspect but fit on the screen properly? I know this might mean that there would be large (black) borders on the top and/or sides and that would be fine. As of now a few games are too large to fit on the screen and thus I can't play them. They may require vertical screen direction, but that ain't happening with a 52" HDTV.
    If anyone has any info on these questions, I'd appreciate it.
    Thanks,
    John
    PS: I have the latest Finless ROM for Android 4.2.2 installed on my device.
    Some APPs are programmed only for a touch screen input will give you this problem! We have no touch screen on these.
    See this APP for how to make those work
    As far as APPs with screen problems. Contact the programmer. They did not make the APP to support other resolutions or orientations. Nothing can be done to solve this.
