New Geekbox MiniTV and 8MP Camera
    More bits for the geeks to add to their Geekbox.
    MiniTV, Geekbox
    Specifications
    Dimensions 192 x 142 x 12.5 mm
    Display 7.9-inch 1024 x 768
    Touch Panel Multi-point capacitive panel`
    Speaker RL = 8O, Peak output =1000mW
    Headphone 3.5mm Headphone Jack
    Positioning Pillars 60mm Location Column x 2 pcs
    Screws 4 pcs
    MIC 42dB
    Connector 314-Pins MXM3 Female
    Extra DC-IN 5V with Over-Voltage Protection
    Buttons 5 Buttons
    Battery Optional Li-Polymer battery
    Camera MIPI-CSI 20-Pins 1.27mm Header
    Convertor NC
    GPIOs 40-Pins 2.54mm GPIO Header
    Mounting Holes 2 pcs for speaker
    2 pcs for GeekBox board
    4 pcs for Location Column
    4 pcs for optional crystal shell
    Package
    1*Geekbox MiniTV
    1*Screw Nuts
    Camera
    Specification
    Model OV8858 R2A
    Dimensions 30 x 25 x 5.4 mm
    Image Sensor Key Features 8MP(16:93264x1036), EIS 1080p(2112x1188), 1080p(1920x1080), EIS720P(1408x792)
    8MP at 30fps
    Focus Auto focus
    Output Interfaces up to 4-Lanes MIPI
    Connector Pins 1.27mm Header
    Power supply 3.3V
    Mounting holes Size: M2 x 4
    Geekbox Landingship
    Geekbox MiniTV
    Geekbox
    That looks cool, geekbox is really delivering what they promised!
      Wheres deal for crystal shell.....😛
        I need to get 3d printer for landingship....
          I will get my Mini TV hopefully soon .. let´s have a look
            Geekbox MiniTV
            MiniTv all up running now, must say looking good and pretty easy to do when you know what needs to be done.
            Tablet Firmware from Forum geekbox,
            Had trouble getting Factory tool to play the game in Windows 10
            Switched to RK Batch tool Piece of Cake.
            All loaded plugged in switched on a few minutes while it sets itself up and Done.
            Looks good for the display size easy to read and touch screen is very responsive, so far very good.
            A few quick Pics
              After installing board onto landing ship and attaching drive to bottom of box. Working good with the drive and duel os. Finding correct linux that kodi works bit of pain but all in impressed with the speed of wifi but overall one of the most fun boxes ive got to date... Kept the case from the small geekbox for travel it fits into pocket and easy to take anyplace. Installed quick clips in place of screws for easy removal.
