Need OPinions! What SD card do you use for the Minix Neo X5?
What's your intended use?
I have a large assortment of SD cards that almost never get used anymore. Though all that I've tested in the X5 work fine.
With 16GB in the X5, I rarely have a need for an SD card. For transferring files between machines, I use a USB stick. And even that's rare.
FWIW, this is what the SD Association says about speed classes. Our little X5 really isn't fast enough to take advantage of the higher speed cards. OTOH - Price differences are small so it makes little difference.
This makes for an interesting read and the results were surprising.
IMHO, read the reviews and buy the cheapest one. If you really feel you need one.
There are currently 1888 users online. 1 members and 1887 guests.
