I just wanted to update anyone who was frustrated from the dts passthrough drops on the gearbest mx III... ( http://www.gearbest.com/tv-box-mini-...tml?vip=150147 )
If you apply the openelec 6.95.3.1 update to your box you will be able to enjoy open elec with wifi support and no more dts passthrough drops...
i've tested dts, dts-hd, dts-es etc.. 7.1 and everything is working fine !
The bluetooth isn't working but I don't really need it...
If you want to try it yourself just grab the update from http://amlinux.ru/image/devel/OpenEL...3.1-update.zip and put it on a usb stick then connect it to your mx and do an update from the apps menu.
After a few min you will have openelec running on your machine and you will be finally be able to enjoy the mx iii s905 box.
btw i did try the openelec 7 as mentioned by the following post http://freaktab.com/forum/tv-player-...uild-available but the v6.95.3.1 is working much better. The 7 version has issues with not passing dts-hd and also scrolling through the movie wasn't smooth as with the v6.95.3.1
Hope it helps you
Ohad.
