I've just bought a OTTTV BOX MXQ Pro, a classic S905. Sadly the stock firmware really suck, it has a lot of problems: it's slow, many of the apps on the playstore can not be installed saying they are not compatible with my device and the automatic updates doesn't work (it say that the update service is not started). I've googled and I can't find any official firmware. Do you know if there is any custom rom for this box?
I'd like to install this rom (http://freaktab.com/forum/tv-player-...5-mxq-pro-s905) but the last replay seems to say that it is not compatibile with the OTT(TV BOX?) one, because wifi and ethernet are no more working after the update. The problem is if I flash and it doesn't work, then I wouldn't able to go back because I can't find an official rom.
