QX1 unable to turn on wifi after a reboot (and self-reboots another time, too!)
    Guys,
    I'm seeing an issue where if I restart the device using Quick Boot or any reboot tool (including ADB), the device restarts TWICE (again right after the bootanimation ends) and when it finally boots back up, wifi is turned off (and can't be turned on again in settings).
    The only way to get wifi back is to physically remove power from the unit and then it works fine.
    This is a pretty serious bug and is extremely annoying.. I've managed to reproduce it across 3-4 QX1s, consistently.
    All are running the 30 May release (iMito_QX1_V422_130530). I'm going to try and update to the latest release, but I just wanted to see if anybody else was seeing this problem on 130530 as I think some people have reported unstability on the latest release.
    Cheers!
    Re: QX1 unable to turn on wifi after a reboot (and self-reboots another time, too!)
    Originally posted by indecided View Post
    Guys,
    Cheers!
    Yes I experimented this problem too, with all 4.2 stock roms in this stick, with custom kernel too,need to test it with 4.1, I didnt test it deeper enought.
    leolas
    My devices:
    Gearbest.com)
      leolas
      I just tried with 4.1.1 dated 130521 - May 21st.
      Same luck.
      Looks like unless the manufacturer fixes this real quick, they're going to be getting a whole lot of returns...
        Yep I have experienced the same on both 4.1 and 4.2 roms
        Sent from my GT-I9300 using Tapatalk 2
          I am experiencing the same on 1080P_V422_130607...
            Seems that it is a general bug
            So we expect an update soon from imito.
            leolas
            My devices:
            Gearbest.com)
