TV provider does not allow TV boxes
I have pre-rooted KIII (K3) Android 5.1.1 Lollipop TV BOX Amlogic S905. My TV provider ( Comcast ) allows to watch live TV and recording on any smartphone and tablet but TV box. Is there any way to pass through the check? I mean modify/replace some system files? Where the information about android device type stored?Tags: None
mxqpro4k Please could you elaborate on your statement? What do i have to change on the build.prop? I also have a provider that allows only certain devices...kind regards
cyber7 (aka Aubrey Kloppers; Cape Town; South Africa)
http://www.cyber7.co.za / http://aubreykloppers.wordpress.com
Device name: Samsung Freaktab
Device model - SF-5800d
It takes a lot more than changing a couple lines in the build.prop file. Brighthouse knows is you are using an hdmi out or not. I have changed device names and spoofed many a device and their software still knows if you are using an hdmi out or not.
Good luck if you ever figure this one out. I simply bought a Samsung tablet and can take it anywhere in the house.
I get an abbreviated channel lineup if I am out on another network away from home (it knows that too).
I was successfully able to spoof an old rk3288 android I had sitting around but the thing is so slow and outdated now that its impractical to use for anything else. To get that device to work on brighthouse I had to use device spoofer and root it, and use hide hdmi app. It was more work than it was worth IMHO.
I agree that it is not so simple as editing the properties file. But I have a Rockchip 3066-based device and use it only on ethernet (in fact, in my own kernel, wifi is broken and causes a hang if you engage it) and the Xfinity app works there even though there is HDMI plugged in. However, it will not work on my S905-based Tronsmart device until I unplug the HDMI. I can view this by looking at the display via Teamviewer. Unplug the HDMI cable and it works. Plug it back in and it stops working immediately. I have heard that some apps also look for rooted devices and other factors. But both of my devices are rooted so that isn't the issue with this app.
Using rootcloak and xprivacy I finally got the xfinity tv com cast app to run on my KIII box via ethernet (or wireless). Add the xfinity app to rootcloak then blocked all receivers via xprivacy (need xposed framework) reboot your device and it should let you watch live streams. Seems to be the only app working for me. I've tested time warner, NBCSN and they don't work. So give it ago guys.
There are currently 2663 users online. 2 members and 2661 guests.
