KS2 Hybrid Amlogic S905 Quad Core Android 5.1.1 DVB T2 Internet Smart Audio System 1GB 8GB WIFI Gigabit LAN
    Something a little different
    DVB-T2
    DVB-T2, the world’s most advanced DTT system, offers more robustness, flexibility and at least 50% more efficiency than any other DTT system. It supports SD, HD, UHD, mobile TV, or any combination thereof.
    Android 5.1 OS
    Android 5.1 OS, rapid and stable, with a redesigned user interface built around a design language known as "Material design", avails the access to over 800,000 apps including Facebook, Youtube, Picasa and more.
    Amlogic S905
    Amlogic S905, a high performing CPU running at 2,000.00 MHz Max., has 4 core(s) which results in extremely efficient multi-tasking in comparison with dual core processors.
    4K Resolution
    The latest in a line of broadcast and media resolutions, 4K is due to replace 1080p as the highest-resolution signal available for in-home movies and television. With a minimum resolution of 3,840 pixels wide and 2,160 pixels high, making it the equivalent to two 1080p screens in height and two in length.
    Gigabit LAN
    Gigabit LAN provides a data rate of 1 billion bits per second.
    This is actually cool, you can have 1 device for 2 jobs and save space. I only don't get why the antenna is outside, is that for WiFi or DVB signal?
    By the way, a $15 off coupon from Geekbuying: KS2AudioBOX
