Tronsmart 908 reactivating per remotecontrol
    Hi everybody,
    since yesterday i have a Tronsmart mk908. everthing works really nice except of the camera (c170) - the quality (picture and video) is no way on a 60`` hdtv only vga or qvga!!!! but this not the problem: i also buyed a Rii remote. The mk908 can be shutted down via remote - how to reactivate via remote?
    Originally posted by Licher Pils View Post
    Hi everybody,
    I don't think it is possible for now. Since my device is plug on my TV, when shuting it down also shutdown the device. If your device is plug permantly I would suggest you to use a deep sleep app, normaly the on/off button will wake it up
    T428 ,Radxa Rock (RR), cs918s v1.0, waiting for my X7...
      what is that???
        what is that???
        Simple application available via google store:
          https://play.google.com/store/apps/d...ller.batrsaver
          and this works also if no battery exists?????
            Sorry I just try and not working
              I tought that was a simple task, but it is not so easy, I try screen off application but my rc13 keyboard is plug when starting the app and it reactivating the device because of the move of remote. But I notice if I position the cursor on the icon, shutdown the remote with the greeen android on remote, then clic left mouse button it work. The device will wake up by the start of remote.
