i have al ittle problem.. few of my files are not working. For example i have a concert, recorded on DVB, onto two channel. This is the same concert, but recorded long time ago in 720 and new one in 1080.
But the 1080 ts file is not playing well..stuttering... and the 720 ts file play fine.
I understand the 1080 requires more power than the 720...but this should not be a problem for this box !!!
Execpt resolution the only difference i see is in the scan type :
1080 file
Scan type : MBAFF
Scan type, store method : Separated fields
Scan order : Top Field First
720 file
Scan type : Progressive
Is there any chance to modify this without reencoding the whole file ? Is it the problem ? I'm recording few file from DVB and can't reencode ll of them...
Or is it the sound which is a problem ?
Thank you bby advance for any clue
Here are the mediainfo result on both files :
1080 file
General
Format : MPEG-TS
File size : 2.15 GiB
Duration : 1h 2mn
Overall bit rate mode : Variable
Overall bit rate : 4 917 Kbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : 27
Duration : 1h 2mn
Bit rate : 4 318 Kbps
Width : 1 440 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Standard : Component
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : MBAFF
Bits/(Pixel*Frame) : 0.111
Stream size : 1.89 GiB (88%)
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio #1
Menu ID : 1 (0x1)
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Codec ID : 129
Duration : 1h 2mn
Bit rate mode : Constant
Bit rate : 224 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Frame rate : 31.250 fps (1536 spf)
Compression mode : Lossy
Delay relative to video : -200ms
Stream size : 100 MiB (5%)
Language : French
Audio #2
Menu ID : 1 (0x1)
Format : E-AC-3
Codec ID : 6
Duration : 1h 2mn
Bit rate : 128 Kbps
Frame rate : 187.500 fps (256 spf)
Delay relative to video : -179ms
Stream size : 57.3 MiB (3%)
Language : qad
Menu
Menu ID : 1 (0x1)
Duration : 1h 2mn
List : 256 (0x100) (AVC) / 257 (0x101) (AC-3, French) / 258 (0x102) (E-AC-3, qad)
Language : / French / qad
Service name : Service01
Service provider : FFmpeg
Service type : digital television
And the 720 file
General
Format : MPEG-TS
File size : 971 MiB
Duration : 1h 2mn
Overall bit rate : 2 169 Kbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : [email protected]
Format settings, ReFrames : 2 frames
Format settings, GOP : M=1, N=50
Codec ID : 27
Duration : 1h 2mn
Width : 1 280 pixels
Height : 720 pixels
Color space : YUV
Bit depth : 8 bits
Writing library : Zencoder Video Encoding System
Audio
Menu ID : 1 (0x1)
Format : AAC
Format/Info : Advanced Audio Codec
Format version : Version 4
Format profile : LC
Muxing mode : ADTS
Codec ID : 15
Duration : 1h 2mn
Bit rate mode : Variable
Frame rate : 46.875 fps (1024 spf)
