Mini m8s - flash brick device
Hi, i have problem with flashing a brick device. I dont have an USB male to male cable. - Is it possible to use the USB Burning Tool to flash the brick device (For MX III i use USB to microUSB and it's working)? There is an other possibility to use microsd card to flash the brick device. I tried to do it according to this https://www.youtube.com/watch?v=ZPtmwwEpB3g . Regrettably i could get only in the CWM mod (without automatic flash .IMG or .ZIP file). In CWM mod i used update apply EXT and i chose .ZIP file, but error has occured. Could you please send me backup ROM in order to install it in device. Than i will install update ROM 104L03. ThanksTags: None
There are currently 1719 users online. 2 members and 1717 guests.
