I have an app from our satellite provider that allows watching of live TV using our subscription login details.
When I launch the app it says DRM initialization failed. I downloaded a DRM info app to check what DRM is installed on the box, and it has Google Widevine. The one issue I see is that it says under Widevine that HDCP is unprotected, which might be the issue? Is there any way to get HDCP to be protected? All the other devices that I check DRM info on have the same DRM, just HDCP is not unprotected. The live TV app works on these devices.
