H96 Plus Android 5.1 Lollipop Amlogic S905 2G/16G KODI 4K TV BOX 2.4G/5G Dual Band WIFI 1000M LAN Bluetooth Media Player
    Model H96 plus, Color Black
    Operating System Android 5.1 Lollipop
    CPU S905 Cortex A53 Processor 2.0GHz
    GPU Penta-Core ARM Mali-450
    RAM 2GB
    ROM 16GB EMMC FLASH
    Network 2.4G /5G WiFi
    Ethernet 10/100M/1000M
    Bluetooth Support BT4.0
    HDMI Port Standard HDMI 2.0
    4*USB, 1*HDMI, 1*RJ45, 1*SD card slot, 1*AV, 1*DC , 1*SPDIF
    Power Power Supply DC 5V/2A
    Package Contents
    1 x TV box
    1 x IR Remote control
    1 x HDMI cable
    1 x Power adapter (A right AC Adapter will be sent as your shipping country)
    1 x User manual
    Geekbuying
    Looks cool, is this an upgraded version?
      looking for firmware for this box?
        I would suggest to anyone thinking of buying this box don't it has no place to get the original firmware I got one here that a friend of mine owns he messed it up loading libreelec Ive looked for days now for the original firmware and it doesn't exist
          Try the Firmware of the Tanix TX3 or TX5 Pro.
          They should work.
          The most S905 Devices are the same inside, only different Housing.
          Neomode
            They should work.
            Neomode
            ok so I have another problem it wont load by sd method nor usb to pc method.Usb to pc the pc only sees the box for a second in usb burning tool then its gone and sd it does nothing just boots to libreelec
              Okay I guess there is a reset on you have to hold to get it burned.
              start USB burning tool load IMG press start then connect the device while reset pin is pressed.
              When it starts you can release the reset pin.
                yep ive done that it connects for a second then dissconnects
                  Okay, I think your USB port did not have enough power for Burning the Box. Press reset hold insert power plug and then USB cable.
                  now it should burn it.
                  Neomode
                    Neomode
                    I did finally get it to connect but the tx3 and tx5,pro files fail at 2%.also mine is a 2gb ram and a 905 not 905x
                      Okay, i will take a look again for a Firmware for you.
                      Neomode
                        thanks for your help
                          got the mxq pro plus file to load to it just booting it now hopefully it works
                            Yes, the same I was thinking should fit your Device.
                            Here is the latest MXQ PRO 4K S905 --> http://moveanything.co/Updates/firmware/MXQ_4K_2017.zip
                            Neomode
                              Neomode
                              do you have that in sd format it keeps erroring low power tried every port I got
